It is currently Mon Jan 26, 2015 8:33 pm
 Post subject: Norton AV and run as
PostPosted: Thu Jul 22, 2004 12:58 pm
XP Pro
I surf as a limited account and I use Norton Anti-Virus. Norton disables "run as" to protect the AV does anyone know how to work around this.
bob
 Post subject: Re: Norton AV and run as
PostPosted: Thu Jul 22, 2004 2:16 pm
rmac3 wrote:
XP Pro
bob
Get rid of Norton. Get AVG Antivirus from www.grisoft.com. This is the easiest manner to see if it is in fact a situation caused by Norton AV or a problem with the OS.
Grisoft does have a free version available if you are concerned.
PostPosted: Thu Jul 22, 2004 4:14 pm
I'd rather be modding!
rmac3 wrote:
XP Pro
bob
Hi Bob,
Are U sure its Norton that is the culprit and not the limited status? I don't run limited, but I haven't seen this problem with AV2004.
Manta
PostPosted: Fri Jul 23, 2004 2:25 am
It is used when you surf as a limited account to keep a virus from disabling Norton. I can see why; my brother uses MicroTrend and a virus disabled it and assigned a new password so he couldn't change it back; he had to reformat. I can run programs from administrator cmd (not very convientent) I guess I will stick with that
Thanks all
bob
PostPosted: Fri Jul 23, 2004 6:31 pm
Folding Master (Top-ranked)
rmac3 wrote:
XP Pro
bob
If you run a properly configured firewall, viruses and trojans cannot install applications without your approval.
