It is currently Thu Jan 29, 2015 8:01 pm
 Post subject: Which DDR2 Memory?
PostPosted: Wed Feb 23, 2005 7:21 pm
To the point:
Any opinions for my new P4 550 system?
Kingston Value Ram KVR533D2N4K2/1G $253
OCZ OCZ25331024VDC-K $260
Patriot PDC1G4200ELK $255
Corsair XMS2 CM2X512-5400C4PRO $190
Thanks for any info...
Mark
PostPosted: Wed Feb 23, 2005 9:02 pm
your gona want the patriot ram, its better can corsait in the ddr2 sector
http://www.zipzoomfly.com/jsp/ProductDe ... Code=83711
its the only ddr2 700 memory, its 250 dolars, it will run at the lowest ddr2 latiencys to date at 533mhz (3-2-2-4), its the same price as the ddr2 533 rated ram, its just officaly runs at ddr2 700
thats the absolute best ram and its the best priced too
PostPosted: Wed Feb 23, 2005 9:15 pm
i second the patriot ram. awesome performance and great for overclocking.
PostPosted: Thu Feb 24, 2005 11:33 am
I have the Patriot PDC21G4200+XBLK and I've been happy with it so far... I checked on a few forums for advice on the Patriot ram, and from what I could tell, they have the best timings you'll get in that price bracket..
PostPosted: Thu Feb 24, 2005 3:12 pm
Thanks...I think you've made up my mind.
PostPosted: Fri Feb 25, 2005 5:06 am
IF you still are looking for ram lokk at this too
http://www.crucial.com/ballistix/
