It is currently Sun May 26, 2013 1:35 am
 Post subject: I need a case...
PostPosted: Fri Feb 18, 2005 10:23 pm
Chief Surgeon
Chief Surgeon
Scenario:
Currently have a 12-drive SCSI RAID-5 array in my 24-bay InWin widebody, which is 5 years old. It's time to replace the array with something a little more modern. So, I'm looking at about 6 SATA Maxtor 300's. I need and love space. :)
What I need:
A Case with minimal 6 HDD Bays (Easy)
A Case that is Silver (Easy)
A case which will accept an Extended-ATX motherboard. (Important)
A Case with 2 Floppy bays (for my 9-1 floppy/Media reader and a 4-port USB bay, or a front USB array built in.
A Case with minimum of 2 120mm fan mounts. I have three lighted 120mm's already.
Conservatively styled.
What I don't need or desire:
Drive Doors, ala Antec 1040B. The location prohibits a swinging door.
60mm or 80mm fans. Too damned noisy.
Funky wild paint schemes, or monster-themed front panels.
BTX. 'nuff said, even if it's available.
Mid, Mini, or Flex ATX form factor.
Optical Drive Cover plates. Same with floppy plated bays. I want to drop my drives in.
USB/1394 ports on the side of the unit. Again, location prohibits this. Plus, why are they called "Front Ports" if they're not on the Front?
What is nice, but optional:
Side Window. I have lights and lighted fans, but it's no biggie.
PSU. I have a Thermaltake/Mad Dog 500w Silent.
Removable HDD Bays.
Optical Drive Rails.
Removable Mobo tray.
Rubber-grommet drive mounts.
The Front USB/1394 ports near the top of the unit. Not on top, like the CoolerMaster WaveMaster.
Please post links to any suggestions. Thank you in advance.
SC64
PostPosted: Fri Feb 18, 2005 10:55 pm
I have one word for you
STACKER!!!!!
11 bays down the front, yes these are 5 1/4 but the case does come with one 4 in 3 convertor and you can get a second for $30ish this would give you room for 8 drives. They each have a 120mm fan on them. Silver and black are is the standard color scheme. There are 6 USB prts and a firewire across the top as well as headphone and mic plug ins. You can purchase a side window for this case as well, as other cooling options. Based upon what you want and don't want this case sounds just about perfect, I know I enjoy mine. I know you said no BTX but it is something you may wish to plan for at any rate.
 Post subject: Re: I need a case...
PostPosted: Sat Feb 19, 2005 4:11 am
Folding Momerator
Folding Momerator
SuperChip64 wrote:
What I need:
Removable HDD Bays.
SC64
SC, how about a budget?
The case Garetjax used a Silverstone SST-TJ03 looks pretty roomy, as does the stacker, which was suggested.
PostPosted: Sat Feb 19, 2005 8:53 am
i would go with thee silverstone case that is in blondie's post. I dunt think the stacker supports the extended mobo.
PostPosted: Sat Feb 19, 2005 9:29 am
Celeron
Celeron
Maybe one of them ginormous server cases would do? ;)
The Stacker looks good and seems like it just fits your bill.
They're closer to the front than the back. :P
PostPosted: Sat Feb 19, 2005 11:52 am
Chief Surgeon
Chief Surgeon
Me thinks the CoolerMaster CM Stacker, with an Extra 4x3 Drive module, will fill my bill.
Blondie & nVidia4Ever: The Silverstone has no 3-1/2" External bays, meaning my 9-1 Floppy/Media reader would need a rail conversion kit. Also, budget wasn't an issue here, that's why I didn't specify one. Sorry. :)
OCNoob: The location of my case prohibits access to the sides, no matter how close.
Thanks for the help. :)
SC64
PostPosted: Sat Feb 19, 2005 12:53 pm
Lian Li pwns!
PostPosted: Sat Feb 19, 2005 1:09 pm
*cries* Other then having two additonal hdd bays, this case meets all of your expectations and is just awesome.
Oh well, you win some and you lose some :cry:
PostPosted: Sat Feb 19, 2005 1:22 pm
Folding Momerator
Folding Momerator
SC64
Sorry, I had big on the mind, not features :roll:
PostPosted: Sun Feb 20, 2005 12:22 am
Chief Surgeon
Chief Surgeon
Sorry, but those damned drive doors don't fit my space. :)
SC64
PostPosted: Sun Feb 20, 2005 12:25 am
The Stacker does in fact support E-ATX boards.
Quote:
The innovative design supports Extend ATX, BTX and dual power supply, making for easy upgrading
from the Coolermaster site CM Stacker page.
PostPosted: Sun Feb 20, 2005 2:01 am
Can somebody please explain what justifies spending $300 on that case?
PostPosted: Sun Feb 20, 2005 5:40 am
Just to toss out another suitable case:
Enermax Maxflow CS-718
Received a decent review in PC Enthusiast magazine.
-Six
PostPosted: Sun Feb 20, 2005 9:06 am
but it has a door.
PostPosted: Sun Feb 20, 2005 9:34 am
The "mesh door" has removable cutouts for the drives, so in actual use, you don't open it up.
PostPosted: Sun Feb 20, 2005 9:45 am
Chief Surgeon
Chief Surgeon
Dammit, [Ch]ams!
Decisions, decisions... :wink:
SC64
