It is currently Fri Mar 27, 2015 8:12 am
 Post subject: WSE Rocket Internet Explorer Browser Object malware
PostPosted: Wed Jul 09, 2014 9:21 am
Hello,
I have Windows 7 Home and the most recent/updated Internet Explorer. Recently I got a hold of one of those fake "RegClean.Pro" malware packages, and it installed several other things - WSE Rocket, NetCrawl, some kind of StormCloudWeather bar, and more. I used (in safe mode after updates) Microsoft Security Essentials, ADWCleaner, JRT, MalwareBytes, HitmanPro, then double checked for manual uninstalls, browser settings, etc. Google Chrome seems to be fine, but Internet Explorer seems to be on lockdown. The browser search object in add-ons is the only thing remaining, but I can't deactivate/uninstall/delete it, and the virus scanners aren't picking anything else up. I'm afraid my computer still may not be 100% secure. Can you please help me figure out how to finish removing this malware/ensure my computer is safe to use? Should I use one of those log programs (like HijackThis, Farbar, OTL, or RegKill) and post a report?
Also, is MSE not enough nowadays? Should I have different/more anti-malware programs for my computer? If so, what do you suggest?
Thanks!
Andrew
 Post subject: Re: WSE Rocket Internet Explorer Browser Object malware
PostPosted: Wed Jul 09, 2014 1:23 pm
Did you try using the "Restore" option in windows to choose a time before you invited that piece of crap into your computer?
Edit:
Did a little googling and found this solution:
http://deletemalware.blogspot.com/2014/ ... guide.html
 Post subject: It's the only way to be sure
PostPosted: Thu Jul 10, 2014 9:17 am
Nasty's solution should work (if System Restore wasn't disabled) and is easy to do.
Otherwise, when someone says they are unsure then the only solution is to nuke it from orbit.
I suspect one of the malware bits added something to IE that broke it. You can try reinstalling IE. But Nasty's is the better idea.
PostPosted: Wed Jul 16, 2014 8:28 pm
Windows 7 is a much better performer of the operating system for me now. I am much familiar with this rather than the other versions.
