It is currently Wed Jan 28, 2015 2:28 am
 Post subject: How to fix: mouse disconnects, reconnects
PostPosted: Sat May 03, 2014 4:39 pm
Dell optical mouse disconnects then reconnects multiple times per minute. PC is unusable with this issue.
Windows 7 64 bit SP1, latest bios, latest USB drivers from my mobo manufacturer. Mouse works fine with other PCs.
Tried USB power setting fixes mentioned in Google search results. Tried disconnecting all USB peripherals (Microsoft Xbox controller, Logitech wireless keyboard, QuickCam, external drive).
Here's my Device Manager. There are two entries for HID-compliant mouse. Tried disabling / uninstalling but the pair comes back after a reboot. Also tried uninstalling everything under Human Interface Devices and both USB Root Hub entries. Help!
 Post subject: Re: How to fix: mouse disconnects, reconnects
PostPosted: Sat May 03, 2014 5:15 pm
  • Try the mouse on a completely different USB port pair
  • Try the mouse on another computer
  • Try another mouse
My guess is the mouse is just going out.
PostPosted: Sat May 03, 2014 5:29 pm
Team Member Top 250
Team Member Top 250
What do you mean "disconnect"? Is it wireless, or is it a wired mouse that Windows keeps losing and then helpfully "finding"? I think you're talking about a wired mouse. I saw Renesas USB3.0. Is that native to your board, or an add-in card? What USB port do you plug in to on this machine?
