It is currently Sat Feb 28, 2015 11:57 am
 Post subject: Budget Build
PostPosted: Thu Feb 06, 2014 9:04 am
Hello all,
I am looking to build a low-cost gaming machine. In the past I have built fairly high-end machines, and I still keep up on the mid to high end hardware, but I am fairly inexperienced in the lower-end stuff. I've put together a build here and would greatly appreciate any feedback. My goal is to stay under $1000, and I should mention I already have all the peripherals and a copy of Windows 7, a SSD I may or may not use and a GTX670 I am taking from another machine.
Thanks in advance for your help.
 Post subject: Re: Budget Build
PostPosted: Thu Feb 06, 2014 9:12 am
You may want a AMD 990 board instead of a 970 board, as there's a warning that indicates you may have to update the BIOS on 970 boards (and you can't update BIOS without a working CPU). I'd also find a cheaper case, $130 just seems a little too much for a "budget" build. You can find plenty of nice cases for under $100. Also, do you need a Blu-Ray drive? If you're not watching movies on it, either get a DVD drive or an external one for when you really need a optical drive
PostPosted: Thu Feb 06, 2014 9:45 am
Good advice all around. I've updated the build sheet.
PostPosted: Thu Feb 06, 2014 9:49 am
Still showing the same parts :D (also the link is somewhat broken)
PostPosted: Thu Feb 06, 2014 9:58 am
Yeah, I'm not sure why the link isn't working correctly. I've tried it a couple of different ways and it's just won't work. Anyway, here is a link to the build:
http://pcpartpicker.com/p/2OmGg
PostPosted: Thu Feb 06, 2014 10:03 am
That looks good.
Though I don't think it'll matter much, see if a 4GBx2 RAM kit will be reasonable. This is mostly to take advantage of dual-channeling.
PostPosted: Fri Feb 07, 2014 12:31 am
Changed. Thanks for th input.
PostPosted: Fri Feb 07, 2014 12:37 am
Changed. Thanks for the input.
PostPosted: Wed Feb 12, 2014 7:46 pm
I've got about the same budget but was thinking something like this instead:
http://www.youtube.com/watch?v=-RUlu7a2 ... tM1udNRujA
What do you think?
PostPosted: Tue Feb 18, 2014 8:52 am
AMD Athlon X4 740 Quad-Core Processor
AMD mATX Motherboard
NVidia GTX 660 2GB GDDR5 Video Card
You can go for this combination too. Its good mid level PC under $900 with 1 TB Hard disk and 8 GB ram. Visit hxxp ://buildmygamingpc[dot]com/shop/amd-captain-class/merope/
