It is currently Tue Mar 03, 2015 1:19 pm
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2
 Post subject: Re: What would be the best bang hardware wise.
PostPosted: Tue Jan 28, 2014 5:24 pm
Yes, it should be fine. Just remember to keep the packaging just in case.
PostPosted: Wed Jan 29, 2014 8:22 am
Nope, spoke too soon. I came back from the dentist this morning and was greeted by this.
PostPosted: Wed Jan 29, 2014 10:29 am
The issue is from that lvrs64.sys file. A Google search found that this is a Logitech camera driver. Either uninstall it or update the driver.
PostPosted: Thu Jan 30, 2014 8:05 am
I went through the steps necessary to fix the mini cam, which was lot surprisingly for a clean boot.
I will probably end up with this http://www.newegg.com/Product/Product.a ... 6814130932, thanks for all the help.
PostPosted: Sun Feb 02, 2014 2:13 pm
Now I got this error, I tried using the supposed hotfix from windows on this but it is incompatible with my version of windows. What would be the best course of action?
PostPosted: Sun Feb 02, 2014 5:27 pm
Your hard drive or RAM is having issues. Open a command prompt as an admin and run
chkdsk /f /r C:\
, you may have to restart for it to actually run. If it comes back with nothing, run Memtest98
More info: http://msdn.microsoft.com/en-us/library ... 85%29.aspx
PostPosted: Tue Feb 04, 2014 9:21 pm
I tried run your string for cmd but it didn't work. However A day earlier I ran a chsdisk on restart and it didn't do anything to help the problem. A couple hours later I got a different code but fail to get it down due to family. I'm using the mem test 86 but Im having trouble figuring it out.
PostPosted: Wed Feb 05, 2014 2:39 pm
my dell computer has memory test scanner on boot and it results yielded nothing. However I got this later
PostPosted: Wed Feb 05, 2014 3:40 pm
Future reference, Google "stop code" the last two hex digits where it says "STOP:". In your picture, you'd be looking for "stop code 0xF4" and the one before that "stop code 0x7A"
Also the command was probably wrong, try
chkdsk C:\ /f /r
In any case your issue is either the hard drive or RAM. Also don't use the built-in memory scanner, it's probably Windows' and isn't exactly reliable. Use Memtest98.
PostPosted: Thu Feb 06, 2014 1:35 pm
I ran the memtest86 for 16 hrs with 15 passes and came up with no errors. So could it be the hard drive or cpu?
PostPosted: Thu Feb 06, 2014 3:02 pm
Hard drive. It's never the CPU.
PostPosted: Fri Feb 07, 2014 9:23 am
Well just before I got here to this site, I got the good old stop 0xF4. Anyway what would be a good brand/model. for the replacement. Also would be able to lend any tips for a external one too?
PostPosted: Fri Feb 07, 2014 9:42 am
If that cloud company Black Burn has any credibility, Hitachi, then Western Digital. Seagate fell off the map by a good margin. As for an external, I usually get an internal drive and an external enclosure. It's upgradable and when it's time to "retire" the old backup drive, you can easily reuse it.
PostPosted: Sat Feb 08, 2014 8:22 am
So either one these will do? Do I have to worry about compatibility like the graphics card and PSU?
http://www.newegg.com/Product/Product.a ... gnorebbr=1
http://www.newegg.com/Product/Product.a ... 6822236244
PostPosted: Sat Feb 08, 2014 11:25 am
The first one is what you should get, since it has more capacity.
And no, you don't have to worry about compatibility with a hard drive.
