It is currently Sat Apr 18, 2015 4:17 am
 Post subject: FIRST build plans
PostPosted: Wed Jan 29, 2014 11:39 pm
I already have a monitor(Vizio 22" razor led), 3x1tb hdd, mouse, and kb
The rest:
Case
Corsair Vengeance C70 Mid-really caught my eye as a convenient and quality case.
$108
Mobo
Asus Z87-Plus....really kinda hard to decide to go pro or not, the wireless would be nice
$160
CPU
i5-4670K 3.4GHZ
$220
GPU
EVGA 770 Superclocked 4GB
$410
PSU
Corsair BS CX600
$58
Memory
Crucial Ballistix Sport 2x4GB
$73
CPU Cooler
Cool Master Hyper 212 EVO...unless i should up it to something really nice just to have no worries. I don't plan on pushing the envelope if i do OC
$35
OS
Windows 7 Home Premium 32-bit
$92
=$1178
includes all Prime shipping from Amazon
....guess that's about it...don't hesitate to make suggestions
Thanks!
 Post subject: Re: FIRST build plans
PostPosted: Wed Jan 29, 2014 11:58 pm
It looks good. Though, you should think about adding an SSD for a bit of boost on the OS.
PostPosted: Fri Jan 31, 2014 9:19 pm
Quote:
Memory
Crucial Ballistix Sport 2x4GB...
OS
32 bit OS - are you sure? If memory (pun intended) serves me correctly, Win 7 32 bit limits the amount of RAM recognized to about 4GB. And the 4GB limit is total memory - including RAM, GPUs and any other component that uses dedicated memory - so your 4GB GPU isn't warranted. Either go with a 64 bit OS (which I recommend) or cut back your RAM and get a GPU with less memory.
Hope this helps
PostPosted: Fri Jan 31, 2014 10:00 pm
Hope this helps
Ya it does help. I just googled and confirmed i need 64-bit.
thanks!
