It is currently Sun Apr 26, 2015 8:08 pm
 Post subject: Debating a video upgrade...
PostPosted: Wed Jan 29, 2014 8:49 pm
I'm looking for a bit of constructive advice; I currently have two GTX 560 Ti cards in SLI and am debating getting something a little faster and less problematic. I'm currently running two monitors and am debating a third. With a budget of $300, should I go up to a single GTX 760, or should I wait for the next price drop? I am running a couple CUDA dependent applications, so I'd prefer to stay with an Nvidia card.
 Post subject: Re: Debating a video upgrade...
PostPosted: Wed Jan 29, 2014 8:53 pm
A single 760 will get you right where you are now, more or less. But you could get a 760 and keep a 560 to use as a pure CUDA accelerator.
PostPosted: Fri Jan 31, 2014 9:31 pm
Quote:
With a budget of $300, should I go up to a single GTX 760...
can you swing a bit more? If so, you could get the MSi 770 currently $320 or the Gigabyte 770 currently $330.
I spent basically the same for my 670 gtx 6 months ago. :( Oh, well.
Hope this helps.
PostPosted: Sat Feb 01, 2014 6:38 am
Hope this helps.
$320 would definitely be within my spending range. Would I be getting a significant performance boost, as far as gaming performance?
PostPosted: Sat Feb 01, 2014 8:18 am
No. To put in perspective, take http://www.anandtech.com/bench/product/829?vs=858 and double the score for the 560 Ti and that's your comparison (roughly)
PostPosted: Sat Feb 01, 2014 9:57 am
I should have clarified. Since your budget was $300, I thought upgrading to the 770 (as opposed to the 760), along with LatiosXT's suggestion of keeping one 560 Ti as a CUDA accelerator, would be preferable. You can sell the second 560 Ti to defray some of the cost of the new 770.
Just a suggestion.
Hope this helps.
PostPosted: Tue Feb 04, 2014 6:59 pm
Thanks for the suggestions.
