It is currently Sun Apr 19, 2015 9:41 am
 Post subject: ram mixing
PostPosted: Sun Jan 19, 2014 12:49 pm
Just wonder if mixing ram is a good idea I currently have 8 gigs. Of patriot ram
http://www.newegg.com/Product/Product.a ... 6820220570
I have two free slots available and have 2- 2 gigs of gskill
http://www.newegg.com/Product/Product.a ... 6820231416
what are your thoughts is it worth it ?
 Post subject: Re: ram mixing
PostPosted: Sun Jan 19, 2014 12:56 pm
You can mix and match RAM from different vendors.
The question is do you really need another 8GB?
PostPosted: Sun Jan 19, 2014 1:05 pm
I don't know if I do but it's just laying around collecting dust the way I see it I should put it to good use you know. Just wondering if there would be issues with the two brands that's all .
PostPosted: Sun Jan 19, 2014 3:04 pm
No, your motherboard doesn't really care who made the RAM, as long as it meets specifications.
PostPosted: Sun Jan 19, 2014 4:24 pm
What if one of the sticks has different voltage one is 1.5v the other 1.6
PostPosted: Sun Jan 19, 2014 4:39 pm
It probably won't work if your motherboard only accepts 1.5V, or the RAM has to be downclocked.
Users browsing this forum: Stam and 5 guests
