It is currently Sun Mar 29, 2015 12:14 pm
 Post subject: Internal microphone doesn't work under some circumstances
PostPosted: Wed Jan 15, 2014 9:50 am
I am currently using an ASUS Zenbook Prime UX32VD-DB71, which has a combo audio jack that supports both speakers and microphones. However, plugging in anything causes the internal microphone to not work. I suspect this is because it thinks that the thing I plugged into the laptop has a microphone, so it automatically disables the internal mic. Any suggestions for how to make the internal mic work while a headset without a mic is plugged in?
 Post subject: Re: Internal microphone doesn't work under some circumstance
PostPosted: Wed Jan 15, 2014 12:42 pm
If nothing in software will fix this (i.e., driver settings to even using Windows' default drivers if compatible), then it's a hardware issue.
PostPosted: Wed Jan 15, 2014 3:18 pm
Check both the driver (Advanced tab), any audio app that came with the laptop/audio chip and Windows' Sound for a check box for exactly what you said: 'Disable internal microphone when external microphone plugged in.'
Also update to latest audio driver for chip, which is Realtek in this case.
Still under warranty?
[url=http://www.asus.com/support/Knowledge-Detail/3/411/UX32VD/146F45C9-8D72-CEBE-198E-B33039EF6EEE/]
Somewhat worthless FAQ[/url].
