It is currently Sun Feb 01, 2015 5:52 pm
 Post subject: Build a pc:Recommended builds Dec 2013.
PostPosted: Tue Jan 07, 2014 10:52 am
Hello, I went out and bought every part on your PC build 2013 review for the Performance build. By any chance do you have a step by step review on putting it together and recommend Bios setup? I have mine together and running but I have a few questions:
* Will the system benefit better installing the 500g ssd drive and the 3k HHD at the 2 brown Intel SATA port or the Marvel grey port? SSD its big enough to house OS and apps/games. HHD will have media files and backup.
*should I have windows catch on for the SSD drive on?
*I noticed the i7 4820k can be run at a faster clock on turbo but at default its running at lower speed. Do you have specs for the Bios input on your Dec 2013 build so I can set it up and get same results as you? I am not scare of the Bios I just don't know enough.
Thank you very much.
 Post subject: Re: Build a pc:Recommended builds Dec 2013.
PostPosted: Tue Jan 07, 2014 11:11 am
The Intel ports as they'll actually operate at 6Gbps. Marvell's probably does operate at 6Gbps but it's gimped because it's connected to the rest of the system through a slower bus interface.
You mean the swap file? Yes, just reduce it to something like 1GB. Some programs don't react well if the swap file is missing.
Adjust the BCLK or multiplier.
PostPosted: Tue Jan 07, 2014 11:16 am
PostPosted: Thu Jan 09, 2014 8:16 pm
Check out this video: https://www.youtube.com/watch?v=7mLP3pGvnDU
I OC'd a 4770k using the multiplier. When I tried adjusting the BClock, the computer crashed, so you might be able to adjust the BClock ever so slightly, but I wouldn't try to OC only using it.
Hope this helps.
