It is currently Sun Apr 19, 2015 12:22 am
 Post subject: Case Fans
PostPosted: Fri Dec 20, 2013 1:05 pm
Hello.
I am looking for 80x25mm PWM case fans that have color leds.
Does PWM <> Color ?
If PWM color leds case fans exist, where do I buy them ?
Lt
 Post subject: Re: Case Fans
PostPosted: Fri Dec 20, 2013 1:11 pm
Take your pick (just make sure to sort by color).
However, I would like to point out getting a PWM bsaed fan is kind of pointless because most fan controllers (on the motherboard or a 5.25" bay type) use voltage adjustment, not PWM.
PostPosted: Fri Dec 20, 2013 2:49 pm
LatiosXT wrote:
....most fan controllers (on the motherboard or a 5.25" bay type) use voltage adjustment, not PWM.
Not if the OP has 4-pin fan headers available.
PostPosted: Fri Dec 20, 2013 3:52 pm
Which most motherboards (except for the CPU) and fan controllers don't have.
PostPosted: Fri Dec 20, 2013 7:22 pm
My motherboard is an Asus P8Z77-V Pro/Thunderbolt.
I may have misread this. The 2 CPU connectors are labeled like this..
    - CPU FAN PWM
    - CPU FAN IN
    - CPU FAN PWR
    - GND
The 3 chassis fan connectors are labeled like...
    - +5V
    - CHA FAN IN
    - CHASSIS FAN
    - GND
Lt.
PostPosted: Fri Dec 20, 2013 8:04 pm
Well, I'll be damned, those are all PWM controlled plugs (I had a gander at the manual)
PostPosted: Sat Dec 21, 2013 8:33 am
I thought as much... All of the Non-PWM fans seem to use molex connectors.
The PWM fans have the 4-pin header? connectors.
Cant seem to find any LED PWM 80x25mm fans :(
Lt
PostPosted: Sat Dec 21, 2013 9:08 am
Go back to my first post in the link, it should be a pre-filtered Newegg search on PWM fans. Just refine it further for the LED you want (you may have to hit the "more options" button)
Unless Newegg thinks 4 pin means Molex.
PostPosted: Sun Dec 22, 2013 11:54 am
Not much luck so far. The 4 pin seems to refer to Molex. Some fans have the header
style connector but its 3 pin :( Such as
http://www.newegg.com/Product/Product.a ... 6835228001
Oy vey ! :?
PostPosted: Mon Dec 23, 2013 11:34 am
LtRav3nw00d wrote:
....Cant seem to find any LED PWM 80x25mm fans :(
Lt
I didn't see any either, just a clear plastic one that was unlit.
Just means search elsewhere.
PostPosted: Fri Dec 27, 2013 6:27 am
Here is one..
http://www.spire-corp.com/system-cooling/
Spire BlueStar 80 LED PCI+PWM
The connector is called a "4 PIN PWM MOLEX 2510"
