It is currently Wed Apr 01, 2015 2:40 pm
 Post subject: disable WINDOWS+L lock key combination
PostPosted: Tue Dec 10, 2013 2:06 pm
I saw that you can use a registry hack to disable this but it appears to only work for accounts that are ADministrators, and not Standard users.
The hack I'm referring to is creating the 32-bit DWORD in the Policies node of the HKEY_CURRENT_USER portion of the registry tree. Again, this works, but only for Admin-type accounts.
Anyone know how to get this to work on a Standard account (or for all accounts on a PC)?
 Post subject: Re: disable WINDOWS+L lock key combination
PostPosted: Sun Dec 22, 2013 7:57 pm
Malware specialist
Malware specialist
You can try using GPO to do this, but unfortunately I'm not aware of a way just for Windows+L.
If the computers have anything besides Windows 7 Professional, Enterprise or Ultimate, you will need to do a hack to get local group policy working, see Here.
To disable the hotkeys, take a look at this.
PostPosted: Sun Mar 09, 2014 6:51 pm
For the record, Microsoft has a FixIt utility that can do this (disable and enable the Windows+L key combination). Just search their website (don't remember what the KB article number was). It will actually disable all Windows+ shortcut keys since it basically disables the Windows key itself.
