It is currently Wed Jan 28, 2015 12:06 am
 Post subject: need to add wireless router to work network
PostPosted: Fri Dec 20, 2013 7:46 pm
So I need to add a wireless router to the work network. Here's how it's set up:
we have a server as a domain controller, that also functions as a DHCP server.
That is connected to two switches (the switches connect all of the clients and printers to eachother).
Now my question is if I needed to add a wireless router to this, would I need a crossover or patch cable (I know most new routers have MDI/MDX and have been told it doesn't matter what cable I use). But, then what about DHCP and allowing the wireless router to access the wired network? Is there anything more I need to do other than disable DHCP on the wireless router?
I personally haven't done this where a Windows server acts as a DHCP server. And we don't use VLANs or anything like that, so we all just share the 192.168.1.x network (we only have about 30 machines so there is no need for VSLM or anything like that). I just need clients that are connected to the wireless router to be able to see the server and other PCs on the wired portion of the network.
 Post subject: Re: need to add wireless router to work network
PostPosted: Mon Dec 23, 2013 6:41 pm
Malware specialist
Malware specialist
Depending on the model of router, you should be able to use any cable. I have heard that some routers, including commercial ones, have trouble handling the differences between crossover/patch. If it were me, I would just wire a crossover cable and call it good.
As for what needs to be turned off, you definitely need to turn off the DHCP server, any type of natting (or you will double NAT and that would be horrible to troubleshoot), firewalls (your company should have one of these in place anyways). What model of router are you hooking up? Are you using any network switches?
