It is currently Sat Jan 31, 2015 8:53 pm
 Post subject: Weird freezing in Windows 7 when switching programs, new pc
PostPosted: Sun Dec 15, 2013 6:17 pm
I built a new PC running Win 7 64bit version. I was using Paintshop Pro X2 to look at some pictures to use for wallpaper. When I switched from that to the wallpaper program, and then back to PSP, it would freeze for about 5 secs. It did it once for about 10-15. It doesn't freeze Windows so I never have to reboot or anything. I read a couple things online where someone had something similar happen and it turned out to be his RAM timings. If you look at my question here: viewtopic.php?f=36&t=242396 I'm wondering if that might be the problem.
 Post subject: Re: Weird freezing in Windows 7 when switching programs, new
PostPosted: Tue Dec 17, 2013 7:06 pm
No ideas?
PostPosted: Tue Dec 17, 2013 9:37 pm
Well if you want to make sure, reset the RAM to stock speed (i.e., disable XMS).
PostPosted: Thu Dec 19, 2013 2:21 am
I would suggest we install the latest mobo chipset driver, reboot, then install the new graphic card driver.
Reboot here is needed for the new chipset driver to take effect to provide a more stable system.
Also install the latest directX driver as well.
Hope this helps.
Bill
Tech Manager, WPTinc.
PostPosted: Thu Dec 19, 2013 6:31 pm
I did all that as soon as I installed Windows. It seems to do the same thing even without XMP profile on. It only seems to do it with Paintshop Pro so I'm thinking it might be a problem with it and 64bit Windows.
