It is currently Mon Apr 27, 2015 10:11 pm
 Post subject: VGA Fan Duct on Cooler Master HAF X
PostPosted: Sun Oct 27, 2013 9:39 am
I have a Cooler Master HAF X and an Asus GTX 770. I was trying to install the VGA duct, but one of the heat pipes on the graphics card is sticking out, and blocks the VGA. Would it work to cut the part on the side that hits the heat pipe? Is this going to wreck the structure of the VGA duct? Should I put a popsicle stick or something to make up or the loss in plastic?
 Post subject: Re: VGA Fan Duct on Cooler Master HAF X
PostPosted: Mon Oct 28, 2013 2:15 pm
Gamerguy14 wrote:
I have a Cooler Master HAF X... trying to install the VGA duct, but one of the heat pipes on the graphics card is sticking out, and blocks....
VGA Duct is for SLI arrangements. It is not needed in your case. <ha witty unintentional pun>
