It is currently Sun Apr 19, 2015 1:27 pm
 Post subject: Slow Internet
PostPosted: Mon Jun 29, 2009 8:25 am
Well here to ask a question is there a way for faster internet? my internet goes 75kb/s which is extremely slow yet some guy i know across the street internet goes 2.1mb/s. So is it the provider the router modem etc that makes it go faster/slower. Just wanted to know anyways to make my internet faster? Any help would be appreciated :P
PostPosted: Mon Jun 29, 2009 8:28 am
What internet package do you have? What does he have? The more you pay, the better and faster your internet will be. You can't compare connections without knowing what you both have as a starting point.
 Post subject: Re: Slow Internet
PostPosted: Sun Oct 27, 2013 8:25 pm
A slow Internet connection could be caused by any number of reasons. It may be connection or traffic problem.
To increase your internet speed use the following tips given below:
1.Contact your ISP and get a latest speed plan from them. Its better way to increase your speed
2.clear cookies from your browser
3.Delete unwanted files
4.PC Optimization:
It is important to clean your PC regularly. It means a normal maintenance tasks such as, cleaning the disks, registry repairs and Disk Derangement.
5.If you are using a DSL connection over your landline, make sure that you have high-quality filters in place to get optimum signal speed.
6.Upgrade your modem.
7.Use Updated browser.
8.Consult with your Internet service provider to ensure that your modem is configured correctly.
9.Replace your telephone modem with a fast-access connection such as wave, ISDN, DSL, satellite, a cable modem.
10.Tweak our router settings
11.Install Antivirus Software.
12.Reduce our bandwidth overhead
After, completing this steps, you can check our internet speed from this site
ScanMySpeed.com
PostPosted: Thu Jan 30, 2014 2:53 am
I recommend you to read this article:
http://www.wikihow.com/Increase-Internet-Speed
PostPosted: Wed May 21, 2014 2:44 pm
It is better to review the data package available with your provider.
PostPosted: Fri Aug 15, 2014 7:25 am
Thanks for this! it works!
