It is currently Tue Mar 03, 2015 7:27 pm
 Post subject: Will this PC build be ok?
PostPosted: Tue Oct 22, 2013 5:42 pm
I am wondering if these parts will work/fit together properly. I was wanting a second opinion before I purchase these.
case - fractal design R4 http://www.newegg.com/Product/Product.a ... 6811352020
CPU - i7 4770k http://www.newegg.com/Product/Product.a ... 6819116901
MOBO - MSI z87 MPower http://www.newegg.com/Product/Product.a ... 6813130691
RAM - crucial ballistix 16gb (2x8GB) http://www.newegg.com/Product/Product.a ... 6820148545
GPU - EVGA GTX 780 http://www.newegg.com/Product/Product.a ... 6814130918
PSU - SeaSonic 850w (ATX12v / EPS12v) http://www.newegg.com/Product/Product.a ... 6817151108
CPU Fan - Hoctua NH-U12S http://www.newegg.com/Product/Product.a ... 6835608040
SSD - Samsum 250gb http://www.newegg.com/Product/Product.a ... 6820147253
HDD - Seagate 1TB x2 http://www.newegg.com/Product/Product.a ... 6822148868
This computer will be for gaming and digital art such as photoshop, maya, zbrush, and UDK
 Post subject: Re: Will this PC build be ok?
PostPosted: Tue Oct 22, 2013 6:54 pm
  • CPU: Drop it to a i5-4670K. The 4770K doesn't offer much performance over the 4670K.
  • Motherboard: I'd probably get something cheaper in the $150-$180 range, simply because when you go more expensive, you get a bunch of "nice to haves" that you may never use.
  • GPU: A GTX 770 or Radeon R280 (or R290 whenever that comes out) would give you a better bang for the buck
  • PSU: If you're planning on using just one video card, 600W-650W should suffice
  • HDD: Notice you have two, if you're going to do RAID0, just get a single 2TB.
PostPosted: Tue Oct 22, 2013 8:46 pm
the i7 was for maya and zbrush mostly. And I do plan on getting 2 video cards as well which is why I chose that PSU.
would duo 770's be good?
PostPosted: Tue Oct 22, 2013 9:45 pm
I'd read up on reviews to see if those two programs or anything like it are included in benchmarks. The problem with the i7 is that it's still a quad core processor at heart, and it really depends on if those programs really take advantage of HyperThreading or not.
And two 770's should be good. Make sure to get a 4GB one or something to start.
PostPosted: Tue Oct 22, 2013 9:54 pm
ok, Thanks for your advice, I'll read up on maya and zbrush. I know that Maya is a very CPU intensive program.
