It is currently Sat Feb 28, 2015 5:13 pm
 Post subject: Help selecting case fans
PostPosted: Fri Oct 11, 2013 6:46 am
Hey everyone :)
I'm trying to build my very first PC. One thing I am having trouble with is how to get the right case fans.
I am buying the Fractal Design Define R4 case: http://www.fractal-design.com/home/prod ... lack-pearl
I'm not sure which size fans I should buy, nor how many fans I should buy. It appears like the R4 comes stock with 2 fans (one for front, one for rear), is this correct? Should I buy more fans?
I won't be overclocking, I'll be running Intel integrated graphics, 1 SSD, 3 HDD, 1 Optical drive, 16GB ram, Intel 4770 CPU.
Would appreciate any feedback on how best to proceed with the fan situation.
 Post subject: Re: Help selecting case fans
PostPosted: Fri Oct 11, 2013 7:49 am
If that is all you are planning on putting in your case and you aren't overclocking, there shouldn't be a need for additional fans in the case itself.
PostPosted: Fri Oct 11, 2013 9:46 am
lftoe wrote:
....I'm not sure which size fans I should buy, nor how many fans I should buy. ....
Should I buy more fans?...
I agree with trl288, you don't need anymore fans other than the ones that come with the case.
From your link:
Front: 1 - 120/140mm fan (included is a hydraulic bearing 140mm Silent Series R2 fan, 1000 RPM speed; 1 - 120/140mm fan (not included)
Rear: 1 - 120/140mm fan (included is a hydraulic bearing 140mm Silent Series R2 fan, 1000 RPM speed)
Top: 2 - 120/140mm fans (not included) - positions also support some models of 240 radiators, depending on configuration
Bottom: 1 - 120/140mm fan (not included)
Side: 1 - 120/140mm fan (not included)
Fan controller: 1 - Integrated fan controller for up to 3 fans (included)
I count five unoccupied fan positions. Two occupied ones: One up front to pull cool air in over your hard drive and the other to exhaust rising hot air out the back of the case.
PostPosted: Sat Oct 12, 2013 9:59 am
From your link:
So the case does come with two fans (front & rear)? Or do I need to buy these?
Thanks a lot guys!
PostPosted: Sat Oct 12, 2013 5:49 pm
from the specs:
"7 - fan positions (2 Silent Series R2 fans included)"
So it comes with 2 fans, front and back
