It is currently Tue Jan 27, 2015 10:22 am
 Post subject: Need recommendation on video card upgrade.
PostPosted: Wed Oct 09, 2013 7:17 am
I have an old and loud Nvidia Geforce 8800GT in a budget workstation I use at work.
By budget I mean (i3, 12GB Ram, 128gb ssd). Nothing fancy, but it gets the job done...most of the time.
I do a lot of video encoding and Photoshop work. So I want a new updated video card that can speed up my rendering while taking advantage of the Cuda cores.
I understand that new mobo and a i7 would probably be better investment, but I don't have the $ in the budget at this point.
Is there an a video card that would be beneficial to me for under $120? Less $ is better.
Thanks!
 Post subject: Re: Need recommendation on video card upgrade.
PostPosted: Wed Oct 09, 2013 7:29 am
Pretty much anything at that price range would be a major upgrade.
PostPosted: Wed Oct 09, 2013 7:41 am
So is the number of cores more relevant than GPU/memory Speeds? I'll won't be gaming on this system.
PostPosted: Wed Oct 09, 2013 8:09 am
Any reason this would be a poor choice? Price is right after the rebate.
MSI N650TI TF 2GD5/OC BE GeForce GTX 650 Ti
http://www.newegg.com/Product/Product.a ... 6814127728
PostPosted: Wed Oct 09, 2013 8:53 am
If this is for CUDA compute stuff, then sure, the number of cores does matter. As far as what you selected, I don't see a problem with that.
