It is currently Mon Mar 30, 2015 6:28 pm
 Post subject: New to PC building and seeking advice
PostPosted: Tue Oct 08, 2013 11:18 pm
My goal is to build a PC that kicks butt when it comes to gaming (I would like to play pretty much anything that comes at me ex. BF4). I'm a first timer, but I've got a list made up and I would like some insight on the parts I selected. Also my budget is still up in the air at the moment (this build is ~$1600) and I haven't picked out an OS or monitor yet, so if there's a way keep this build at about the price it's at now with a good OS and nice monitor included that would be awesome. If there are better options/deals out there that would decrease the overall price of this build please let me know as well.
Case: Corsair Carbide Series Air 540 (CC-9011030-WW) Black Steel / Plastic ATX High Airflow Cube Case
MOBO: ASUS MAXIMUS VI HERO LGA 1150 Intel Z87 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
GPU: MSI Gaming N770 TF 2GD5/OC GeForce GTX 770 2GB 256-bit GDDR5 PCI Express 3.0 SLI Support Video Card
PSU: XFX Core Edition PRO750W (P1-750S-NLB9) 750W ATX12V 2.2 & ESP12V 2.91 SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Active PFC
CPU: Intel Core i5-4670K Haswell 3.4GHz LGA 1150 84W Quad-Core Desktop Processor Intel HD Graphics BX80646I54670K
SSD: SAMSUNG 840 Pro Series MZ-7PD256BW 2.5" 256GB SATA III MLC Internal Solid State Drive
RAM: Crucial Ballistix Sport 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model BLS2KIT8G3D1609DS1S00
HDD: Western Digital WD Blue WD10EZEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive Bare Drive - OEM
Optical Drive: SAMSUNG DVD Burner 24X DVD+R 8X DVD+RW 8X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 24X CD-RW 48X CD-ROM SATA Model SH-224DB/BEBE - OEM
Cooler: COOLER MASTER Hyper 212 EVO RR-212E-20PK-R2 Continuous Direct Contact 120mm Sleeve CPU Cooler Compatible with latest Intel 2011/1366/1155 and AMD FM1/FM2/AM3+
All help is appreciated, Thanks!
 Post subject: Re: New to PC building and seeking advice
PostPosted: Wed Oct 09, 2013 7:20 am
Just some two cents.
Motherboard
I would find something cheaper, like in the $120-$150 range. Take a look at the motherboard's features, are you going to use them all? The motherboard is something that doesn't really perform any better the more expensive you go. The more expensive ones just have nice-to-have features that can usually be done through alternate methods.
PSU
If this is a single video card system and will be, then you can drop the wattage down to 600W or so.
CPU
Are you going to overclock the CPU? If not, you can shave a few by going with the non-K part
RAM
8GB is enough really. Unless you have something memory intensive you use like video editing or multiple VMs or something.
PostPosted: Sat Oct 12, 2013 6:03 pm
Everything that latios said.
Any reason why you want that case? It's probably $120. There are nice cases in the $80 range such as Fractal Define R4. I have a nice big Antec 302 which was around $50 and does well.
Also, you can save around a $100 or so by going with a 120gb SSD instead of the 256GB. You can put your OS on it and still have enough space for a few games and programs.
With all these downgrades, you probably save $250. Put that in for a good monitor and the OS.
