It is currently Sun Jan 25, 2015 7:25 pm
 Post subject: Windows Lost Search Function
PostPosted: Sat Sep 28, 2013 5:29 pm
My Start menu used to have a search function which is GONE now. Also, every folder USED to have a search function in the top right corner and THAT is gone too. Windows 7. Any way to get this back???
 Post subject: Re: Windows Lost Search Function
PostPosted: Sat Sep 28, 2013 5:54 pm
Uh... screenshot please?
EDIT: in the mean time there's two things that may work
  • Go to Control Panel -> Programs and Features -> Add/Remove Windows Features (left panel) -> Check "Windows Search"
  • Repair install Windows 7
PostPosted: Sun Sep 29, 2013 4:57 am
Looks like your first tip paid off. I was messing around in there turning things off and on.
You need a screenshot of a missing search bar?? :D :D
Thanks.
PostPosted: Sun Sep 29, 2013 9:22 am
It's a case of "pics or it didn't happen"
PostPosted: Mon Sep 30, 2013 5:11 am
Sorry.....I got better things to do with my time then to "make up" phoney problems with my rig.
PostPosted: Sat Nov 02, 2013 1:22 am
Have you checked that your system not get corrupted?
Otherwise you also try to restore your setting options in Control Panel to get the Search option back.
