It is currently Thu Jan 29, 2015 10:40 am
 Post subject: ASUS MOBO
PostPosted: Wed Sep 25, 2013 4:43 pm
Redoing my old Asus M4A79 Deluxe which used to have an AMD A3 chip in it. Need to know if it will fit an AMD A3+ chip.
 Post subject: Re: ASUS MOBO
PostPosted: Wed Sep 25, 2013 5:51 pm
AM3 boards are typically compatible up to the FX series.
PostPosted: Thu Sep 26, 2013 4:22 am
Straight from the Asus Specs page: http://www.asus.com/Motherboards/M4A79_ ... ifications
CPU
AMD AM3/AM2+/AM2 ;Phenom™II /Athlon™II /Phenom™ / Athlon™ /Sempron™ Processors
AMD 140W CPU Support
AMD Cool 'n' Quiet™ Technology
Support 45nm Phenom™ II CPU
Chipset
AMD 790FX/SB750
System Bus
Up to 5200 MT/s HyperTransport™ 3.0 interface for AM3 / AM2+ CPU
2000 / 1600 MT/s for AM2 CPU
No 3+ on that list.
PostPosted: Thu Sep 26, 2013 4:34 pm
oldwizkid wrote:
Straight from the Asus Specs page: ....
Yes, but it ain't the specs page you look at...it is the CPU support page.
PostPosted: Thu Sep 26, 2013 4:38 pm
Be sure to upgrade to the latest BIOS revision BEFORE swapping CPUs. But like the oldwizkid says, no FX for you.
PostPosted: Thu Sep 26, 2013 7:32 pm
Not worried about FX series. Worried if an A3+ chip will fit the A3 board.
PostPosted: Thu Sep 26, 2013 7:38 pm
Your motherboard supports:
  • Sempron
  • Sempron 100
  • Athlon X2/X3
  • Athlon II X2/X3/X4
  • Phenom X3/X4
  • Phenom II X2/X3/X4/X6
FX is the only AM3+ chip.
PostPosted: Thu Sep 26, 2013 7:40 pm
Actually, since we're here, I'll take any suggestions on a chip for this board. Just the best bang for the buck kind of chip.
PostPosted: Thu Sep 26, 2013 7:53 pm
Phenom II X6 1060T or Phenom II X4 970 BE. Should be at most $150
PostPosted: Thu Sep 26, 2013 7:57 pm
Yeah, tough part is gonna be finding someplace that keeps them in stock. Thanks.
PostPosted: Tue Oct 01, 2013 1:45 am
Yes, the upgrade on the Bios may need to take the new CPU.
If the board can see the new CPU directly, I would suggest not to temper the Bios upgrade.
Hope this helps.
Bill
Tech Manager, WPTinc.
PostPosted: Sat Oct 05, 2013 10:45 pm
Forgot to ask......I'm not gonna have any problem with the slower, DDR2 memory and, let's say, a Phenom II 965 3.4ghz chip?
