It is currently Fri Apr 24, 2015 9:16 pm
 Post subject: Upgraded laptop CPU cause shutdown
PostPosted: Wed Sep 18, 2013 9:02 pm
Hello, I recently upgraded the CPU in my laptop from a Celeron B820 to an i3 3110m. I am now facing a really annoying problem. Every 30 minutes the laptop would shutdown without warning. The chipset is HM70 if that plays a role in this. If it does I find it strange that it works problem free for 30 minutes then just shuts down. Any help is appreciated.
Thanks in advance,
Phil
 Post subject: Re: Upgraded laptop CPU cause shutdown
PostPosted: Wed Sep 18, 2013 9:23 pm
Check the system log (Control Panel -> Administrative Tools -> Event Viewer -> System) and look for errors.
PostPosted: Thu Sep 19, 2013 2:27 am
The only error I could find stated that the system did not shutdown cleanly. The source is Kernel-power.
PostPosted: Thu Sep 19, 2013 8:23 am
Does the laptop feel really hot where the processor is?
PostPosted: Thu Sep 19, 2013 10:24 am
Everything us nominal except for the shut down after 30 minutes
PostPosted: Thu Sep 19, 2013 10:35 am
Leave the laptop on in BIOS and see if it shuts down. And if it does, then I suspect your laptop just hates it.
PostPosted: Thu Sep 19, 2013 11:20 am
I tried it in the bios and it shuts off too.
PostPosted: Thu Sep 19, 2013 12:19 pm
Plug the old processor back in and if the problem goes away, it doesn't like the new processor.
PostPosted: Thu Sep 19, 2013 1:17 pm
The old processor works fine, guess this laptop does not like this new processor then. Thanks for your help.
PostPosted: Sun Sep 22, 2013 7:47 am
Did you upgrade the heat-pipe array to the correct one for the CPU you bought? Its shutting down from overheating more than likely.
PostPosted: Sun Sep 22, 2013 8:38 am
I already covered that base earlier with him and both processors have the same TDP anyway.
