It is currently Sun Mar 01, 2015 9:19 pm
 Post subject: Help with 1st build for LoL.
PostPosted: Sun Sep 15, 2013 7:45 pm
So I have spent too much time looking at all these parts. My budget is $600 and I am trying to get the most out of it. However I have heard that LoL is not a very intense game when it comes to graphics, so I feel as though I am over building my computer. I was looking at an HD 7850 for graphics and a FX-8350 for a CPU. Is this over kill for LoL? What would be an ample cpu/gpu combo to run this game on max settings or close to max (if I have to play on high vs very very high I can live with that).
All this computer is for is League of Legends, I don't play any other computer games...Please keep that in mind.
 Post subject: Re: Help with 1st build for LoL.
PostPosted: Mon Sep 16, 2013 12:08 am
http://pcpartpicker.com/p/1Em45
It's $584 upfront, but $528 after rebates. All this gets you is a FX-6100 which is still pretty decent, but if you want a FX-8350 then you're going to have to spend $650 upfront before rebates lower this to $598 or so. The thing is the two parts you want total $330 off the bat... and everything else is pretty much the cheapest I could get it to without giving you doggy doo quality.
PostPosted: Mon Sep 16, 2013 10:24 am
Would the i5-3570 with integrated graphics card be a better buy? I'd save some money by not getting a graphics card but is the integrated gpu on this enough for lol?
PostPosted: Mon Sep 16, 2013 11:29 am
Well, people say you can get about 30-40FPS on high with one. But I'd opt for a Haswell chip rather than an Ivy Bridge chip.
PostPosted: Mon Sep 16, 2013 7:39 pm
Why is that? I know very little about this type of stuff, still researching could you please elaborate?
So after much internal debate I think my best option is to go with a core-i7 cpu (w/HD 4000 internal gpu). From what I have seen this will give me what I want to play on med to high settings. But most important it gives me a good base point to go from in the future. I will probably end up adding an additional GPU in the future should I decide that I need one, but I beleive its the best bang for the buck.
So my new question becomes, how big of a PSU do I need. The websites I have been looking at say I need less then 100w PSU?!??! If this is the case then I can just go with a nice little <$40 psu and save even more money..
PostPosted: Mon Sep 16, 2013 8:12 pm
Because I don't believe you should get last generation tech unless there's some absolute need :D
As for what you think you should get, no. A Core i7 will take out half your budget for performance that is meh. If you got a Core i5, the price difference would've nailed you a cheap graphics card that would dominate the HD4000. Also, unless you get a i7-4770R, a Haswell i5 or i7 has the same HD Graphics GPU anyway, so you're not going to get anything out of it anyway.
On that note: http://pcpartpicker.com/p/1EGyi
PostPosted: Mon Sep 16, 2013 9:11 pm
Thx for the help so far! This got me thinking; why not settle for a core i3 with the hd 4600. I mean will a i5 really make that much of a difference when it comes to playing LoL? Besides that all I do is surf the web, literally no other gaming besides LoL on the computer. From what I have read the i3 has a higher clock speed but only 2 cores, and I have also read that LoL doesnt use more then one core anyways, or something along those lines...
Let me know your thoughts on this...
PostPosted: Mon Sep 16, 2013 9:49 pm
You know, if all you're doing is LoL, we could just get you an APU and call it a day.
PostPosted: Mon Sep 16, 2013 10:25 pm
APU? Isnt that the same as a cpu with integrated graphics?
PostPosted: Mon Sep 16, 2013 10:47 pm
Kind of. I'm talking about AMD's offerings specifically.
