It is currently Tue Apr 28, 2015 8:40 am
 Post subject: Got my 2nd 780 and
PostPosted: Sun Sep 08, 2013 8:50 pm
Got my 2nd 780 tday, just ran a few benchs. Heres they are:
http://www.tgupdate.com/Desktops.html
So should I try and push em or say to heck with it since.....they'll run anything anyway? I have yet to pair em up with 3 27"s to race thesurroundgamer but maybe ill drag a cpl screens from upstairs down to the PC room to try it out.
 Post subject: Re: Got my 2nd 780 and
PostPosted: Mon Sep 09, 2013 6:54 am
Million Club - 20 Plus
Why 'push'em' if they run everything now? Overclocking takes more power and it is power that you would just be wasting for no good cause. (Other than a higher electricity bill.)
If in the future the frame rates come down enough that you see stutter or something, then I would 'push it'.
PostPosted: Mon Sep 09, 2013 9:17 am
Exactly, this is why I don't suggest multi-video card systems because a single card can take care of up to 2560x1600 on maximum detail at smooth framerates easily. And if you're getting over 60FPS, there's no point, because most monitors have a refresh rate of that and all you're going to get is screen tearing.
PostPosted: Mon Sep 09, 2013 10:28 am
LatiosXT wrote:
Exactly, this is why I don't suggest multi-video card systems because a single card can take care of up to 2560x1600 on maximum detail at smooth frame rates easily. And if you're getting over 60FPS, there's no point, because most monitors have a refresh rate of that and all you're going to get is screen tearing.
I agree for the most part. I dont care if you have 4 Titans, you aren't running every game at 60fps 100% the time. Just the crummy "coding" in some areas of some games will slow even beastly systems down. But with TWO 780s I am seeing that those instances are farfar fewer so, why not. I
PostPosted: Mon Sep 09, 2013 6:49 pm
Unless you want to play star citizen on max settings.
But hey, that game isn't out and won't be for at least a year and a half.
My wallet will hate my when that game comes out though, because I doubt my wimpy single 760 can handle that game.
PostPosted: Mon Sep 09, 2013 7:19 pm
That to me just suggests the game isn't optimized. Like how CryEngine 2 is a performance killer but the same machine will run CryEngine 3 better for the same visual quality.
