It is currently Sun May 03, 2015 12:53 am
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
 Post subject: Re: Gaming Laptop recommendations..?
PostPosted: Mon Aug 12, 2013 11:24 am
No problem!
If it helps narrow it down, this handy checklist should narrow things down:
  • Preferred screen size
  • Weight
  • If it uses GPU switching (e.g., NVIDIA Optimus), in case you wanted something that lasts a while on battery if not gaming.
  • GPU that you want. Use this list to get an idea where GPUs fall.
The rest is sort of irrelevant for gaming PCs, in the sense that either you get high-end components or they don't really matter in gaming that much.
PostPosted: Fri Aug 23, 2013 10:22 pm
I am currently using a sony vaio i7 with nvidia graphics card, runs most of the newest games and good settings.
i will recommend you to research first, don't just buy it by looking at company name like Alienware etc.
