It is currently Sun Feb 01, 2015 1:54 pm
 Post subject: AMD CPU differences
PostPosted: Tue Aug 20, 2013 1:37 pm
I am trying to find out if there is a difference between an AMD Athlon 64 X2 and a AMD Athlon 64 X2 Dual Core. cpubenchmark.net has them as two different processors(AMD Athlon 64 X2 Dual Core 4200+ and AMD Athlon 64 X2 4200+). It does not give a specific part number so I cant search for the information. Are these different generations of the Athlon. What is the difference(socket type ect..)in the 2.
 Post subject: Re: AMD CPU differences
PostPosted: Wed Aug 21, 2013 2:22 pm
As best as I can remember, both chips are, like you said, are Athlon 64 dual-core design, fit into the AM2+ socket, and are clocked at 2.2 Ghz.
The only difference is the L2 cache - the 4200 has a 512mb L2 and the 4400 has a 1mb L2.
I owned a 4200 several years ago and it was a pretty good chip for its time. But that was 4-5 years ago and the more recent Phenom and FX chips has far surpassed it in performance, as well as drawing less power.
PostPosted: Thu Aug 22, 2013 10:02 pm
The biggest difference is Dual Core~
PostPosted: Thu Aug 22, 2013 10:47 pm
The Athlon 64 X2 4200+ is probably the Socket 939 version while the Athlon 64 X2 Dual Core 4200+ is probably the Socket AM2 version.
PostPosted: Fri Aug 23, 2013 2:42 am
Both are dual core - the "X2" in the name indicates dual cores. As mentioned earlier, both are Socket AM2 chips. The later Athlon 64 chips and the Phenom line indicated the number of cores by the designation "X--" after the name -e.g. Phenom X4 is a quad core, X2 is a dual core, etc. I actually had a Phenom X3, which was a tri-core. In reality, it was a quad core with one of the cores turned off. This is a common practice with chip makers - if a portion of a chip is defective, it can be turned off and sold as a lower priced model. The Athlon II models were actually Phenom chips with the L3 cache disabled. Intel does the same thing with the current Pentium and Celeron models - both are current Sandy Bridge and/or Ivy Bridge chips with various portions turned off.
PostPosted: Fri Aug 23, 2013 8:40 am
Million Club - 5 Plus
I'm presently running a Athlon II X4 640 (Propus core). Too bad there isn't a way to enable that disabled L3 cache like you can a disabled fourth CPU core in an X3!
PostPosted: Fri Aug 23, 2013 10:10 am
If it's Athlon 64, it's a K8 processor. If it's an Athlon II, it's a K10 processor. Not to mention, that K10 processors dropped the PR number, and both models OP posted have a PR number.
