It is currently Sun Apr 26, 2015 9:40 pm
 Post subject: Getting into PC Gaming; Build or Buy ? HELP
PostPosted: Fri Aug 09, 2013 4:48 pm
So, a few days ago I decided to get into PC gaming but I didn't really know where to start. I have been searching the web and researching gaming PC's and parts by themselves too. I've been debating whether I should buy a PC already made or build one myself. If what games I'm playing on it matter a lot then these are the games I plan to play: Battlefield 3/4 and other shooters, Watch Dogs, Batman, Payday, Mortal Kombat, and some racing games too.
I've been leaning towards making my own and here are the parts that I got off a website that promised this would be a good build for my budget of around $1000:
Windows 7 Home Premium ----- Operating System $ 70
NZXT Phantom 410 ----- Case $ 85
Intel i5-3570K ----- CPU $ 205
Asrock Z77 Pro 3 ----- Motherboard $ 85
Corsair Vengeance LP 8GB (2x4GB) DDR3 1600 ----- RAM $ 70 - 100
Asus GTX 660 Ti ----- GPU Graphics Card $ 210
Seagate Barracuda 1TB ----- Hard Drive $ 65
Samsung DVD RW ----- Optical Drive $ 15
Thermaltake Smart Series 750w ----- Power Supply $ 85
Viewsonic VX2370Smh-LED ----- Display/Monitor $ 160
Cheap Mouse and Keyboard $ 20
(I plan on using a controller since that's what I'm use to)
TOTAL $1100
Would this be a good PC or should I change some parts or buy an already built one ? Please help in any way you can.
 Post subject: Re: Getting into PC Gaming; Build or Buy ? HELP
PostPosted: Tue Aug 13, 2013 1:17 pm
If you want to shave a bit of money off and don't intend on overclocking you can get the non-K version of the cpu and an h87 instead of a Z motherboard....
also consider getting the 760 instead of the 660 for a GPU
PostPosted: Wed Aug 14, 2013 12:28 pm
I think that the 750W PSU might be too much. You can probably get away less power
PostPosted: Wed Aug 14, 2013 12:33 pm
If you're still teetering on the fence of building your own computer or buying a prebuilt one, just remember that if you build your own, you're basically on your own more or less. Say you put everything together and it doesn't boot, it may be a long or short road depending on how quickly you find out what's going on. If it's prebuilt, you're pretty much guaranteed a working computer out of the box, preconfigured and ready to go.
If you're okay with that though, build on!
PostPosted: Thu Aug 15, 2013 6:19 pm
I don't plan to overclock right away but later when my PC starts to get out of date I would like to try it. The reason I chose the 750W is because the same version of 550W is only $10 less. So later when I upgrade and need more power I won't have a problem. And I really would like to build my own unless someone could suggest a very good pre-built PC for about the same price.
