It is currently Sat Jan 31, 2015 1:56 am
 Post subject: posted a trick on the forum and its legit but got deleted.
PostPosted: Fri Aug 02, 2013 10:31 am
It is a real windows trick for windows 7 and it gets deleted.
I did not post in the wrong area either.
I feel kinda pissed but also I suspect since I am new here that maybe
some mods do not like "new" know it all tech nerds showing up telling windows tricks.
So what gives?
A. I did not cuss
B. I did not flame
C. I did not cause or create hatred to grow between community forum members
D. I did not lie. The steps were told in a very easy manner for all to understand.
E. It was dead on subject with the thread that it was a TRICK. NOT A HACK
F. I did not post the trick in all CAPS.
G. I only used english.
H. The trick I gave should work on all versions of windows but I did state I only tried it
on the enterprise version as it was how I discovered it while I was at work.
No reason given to why it was deleted so I suspect the mod must be 12 years old or younger.
So please revive my post or should I try posting it again?
 Post subject: Re: posted a trick on the forum and its legit but got delete
PostPosted: Mon Aug 05, 2013 5:59 am
Moderator
Moderator
TONS of spam comes through here every single day. It probably got deleted by mistake. No harm, no foul, just post it again and I will personally look for it.
PostPosted: Tue Aug 06, 2013 2:33 pm
Nope, I'm pretty sure it was a conspiracy to keep you, personally, down.
PostPosted: Thu Aug 08, 2013 10:14 am
Moderator
Moderator
Don't give away our secrets.
PostPosted: Thu Aug 08, 2013 1:43 pm
I didn't.
It was a trick.
PostPosted: Fri Aug 09, 2013 6:05 am
Moderator
Moderator
8)
Nice
