It is currently Thu Jan 29, 2015 3:49 am
 Post subject: I have some questions about the GTX 780
PostPosted: Tue Jul 16, 2013 8:39 am
I want to get it and I finally have the money. I have a few questions before I do buy it though.
1) Will a 650 watt PSU be enough? I currently have the following PSU: 650 Watt -- NZXT HALE82N-SI / 80+ Bronze
2) Will it fit in PC? I read that space is an issue. My tower is: Chimera Inferno 4SE Gaming Case - Flame, from ibuypower. Its a pretty big case, though not nearly the biggest I've seen. Definitely bigger than an everyday case though. I currently have the GTX 650, so I assume it would be around the same size. I have no idea though.
3) How does SLI work, and would this card work in SLI with my current 650? Should I try hooking them together if I get it, or would it be a waste of time?
4) Finally, are there any deals on it anywhere? I see it on newegg for about 650, but thats without shipping and a warranty.
 Post subject: Re: I have some questions about the GTX 780
PostPosted: Tue Jul 16, 2013 1:42 pm
Yes.
The card is 10.5 inches long, so reserve about 11 for breathing room.
SLI only works with identical GPUs.
Do some shopping at other vendors, like TigerDirect, Fry's, Microcenter, etc.
