It is currently Wed Mar 04, 2015 1:14 am
 Post subject: PC Cleaner Pro
PostPosted: Thu Jun 13, 2013 8:46 pm
I just got home from troubleshooting a friend's computer. Part of the problem(s) with this particular system turned out to be the fact that PC Cleaner Pro installed itself on this computer without the owner's knowledge. Nonetheless, upon researching this program (which purports to be a registry cleaner and optimizer as well as an antivirus program--Windows Security Center sees it as an antivirus program, too!), it's interesting to note that MalwareBytes has not targeted this program as malware as it considers it to be legitimate. Is this because it's advertised as a "Microsoft Certified Partner"? And, if it is legitimate, how come it installs itself by piggybacking on other legitimate software (such as PDF Creator) and before doing so, why does it not detect other legitimate antivirus software and ask you to remove it before installing itself on your computer? And if you choose to uninstall PC Cleaner Pro, why can you not find a free removal tool for it (like you can for Norton, AVG, McAfee, etc.) that removes all traces of the program that the program's built-in uninstaller will most likely leave behind? As far as I am concerned, this program behaves too much like malware (particularly in that it "finds" problems on your computer--even when unsolicited--then offers to fix them, but only if you buy the product first) to be considered a legitimate program. Woof!
 Post subject: Re: PC Cleaner Pro
PostPosted: Sun Jul 14, 2013 10:55 am
did your friend have any dedicated anti virus installed because indeed this is malware and should have had been detected.
PostPosted: Sun Jul 14, 2013 8:40 pm
Yes, she had Norton 360 Premiere v6.0 installed on her computer.
PostPosted: Tue Jul 16, 2013 3:18 am
hmmmm....should have detected it.
PostPosted: Thu Jul 25, 2013 11:10 am
Do we know what it piggy backed on? If so it may be a clue as to why malware bytes missed it.
PostPosted: Thu Jul 25, 2013 12:14 pm
It piggybacked itself on PDF Creator (see my original post at the beginning of this thread).
PostPosted: Sat Feb 21, 2015 3:52 pm
This kind of crapware installs itself if it is piggybacked on other legitimate software if you choose the "Express Install" option of the program that you wanted on your computer in the first place. By selecting this option, you automatically consent to its EULA (assuming it has one) and that is most likely why it is not detected by a security program such as Norton. Also, Norton's spyware/malware detecting ability is mediocre at best and will not detect this program as such. I use Norton 360 as well, but depend on it to protect my computer via antivirus and firewall protection, and supplement it with both MalwareBytes and SuperAntiSpyware. Just my personal opinion.
