It is currently Sat Apr 18, 2015 4:17 am
 Post subject: I need help building a new pc
PostPosted: Fri Jul 12, 2013 4:05 pm
I'm building a gaming pc and my budget is a little over $1000.
here are the components:
Intel Core™ i5-3570
ASUS P8Z77-V LK, LGA1155, Intel® Z77
CORSAIR 8GB (2 x 4GB
EVGA GeForce® GTX 660 SuperClocked 1046MHz
WESTERN DIGITAL 1TB WD Caviar® Black
NZXT Guardian 921 RB Black Mid-Tower Case
COOLER MASTER Silent Pro M2 720W Power Supply
I need help making some adjustments because I'm not going to overclock anything. I don't even know how to use the bios so I need a cheaper motherboard that can still support my components and also recommendations for a better graphics card within the price range of the gtx 660 and a power supply that doesn't die quickly.
thanks.
 Post subject: Re: I need help building a new pc
PostPosted: Fri Jul 12, 2013 5:16 pm
I would get a Core i5-4670 and a Z87 board. And you can tone the PSU down to 600W. If you want something quality, Seasonic or Corsair will work.
PostPosted: Fri Jul 12, 2013 8:26 pm
how better is the i5 4670 comapred to the 3570?
PostPosted: Fri Jul 12, 2013 8:58 pm
It's not exactly that much better, but I only suggest such to keep up to date.
PostPosted: Fri Jul 12, 2013 9:21 pm
http://www.amazon.com/MSI-Computer-Corp ... ywords=h77
will this support the cpu
PostPosted: Fri Jul 12, 2013 9:42 pm
No, it has to be socket LGA 1150
PostPosted: Fri Jul 12, 2013 9:45 pm
but that motherboard is compatible with the 3570?
PostPosted: Sat Jul 13, 2013 6:54 am
Yes, that motherboard is compatible with the 1155. To be frank, I feel that most motherboards are the same feature-wise up until a certain price point, and then they start adding features to differentiate themselves. As long as you buy from ASUS, ASRock, Gigabyte, or MSI, you'll be fine.
PostPosted: Thu Jul 18, 2013 11:10 am
To bad we can't give 'Rep' on this site, because I would have given you some for this post. Although I prefer the 3570 the 4670 is also an excellent choice.
