It is currently Sun Apr 26, 2015 11:40 pm
 Post subject: Micro ITX
PostPosted: Fri Jul 05, 2013 1:04 pm
I was thinking of a Micro ITX or Mini ITX build, what CPU coolers and power supplies should I look.
Socket 1150 Z87 or H87. Doesnt really matter to me.
 Post subject: Re: Micro ITX
PostPosted: Fri Jul 05, 2013 9:18 pm
Take your pick of motherboards. As for cooler, Cooler Master Hyper 212 should do, and a PSU, it depends on what else you're getting, but if it's a single video card setup, no more than 600W should do. 750W-800W for SLI/Crossfire. As for brands, Seasonic or Corsair.
PostPosted: Sat Jul 06, 2013 12:04 pm
Im going with single card and xeon x3 cpu
PostPosted: Sat Jul 06, 2013 6:20 pm
There's no motherboards then if you want a LGA1150 Xeon proc in Mini-ITX
PostPosted: Sat Jul 06, 2013 7:48 pm
The ASRock under H87 support that proc
    PostPosted: Sun Jul 07, 2013 7:45 am
    http://www.gigabyte.us/products/product-page.aspx?pid=4601#
    PostPosted: Mon Jul 08, 2013 8:59 am
    I'm more wondering why you want a Xeon processor when it won't give you much of a performance gain for what it's worth. Unless you're doing server/workstation stuff.
    PostPosted: Thu Jul 11, 2013 11:44 am
    Because I want something that can process photo and video editing quicker. I am not a pc gamer. I think the X3 were built for this reason.
    I could go with Integrated graphics or a single gpu card. Also, with the leak Intel Map. the BGA 4770R seems will be released soon and I could
    go that route.
    A Intel NUC with 4770R could make a sweet compact machine.
    PostPosted: Thu Jul 11, 2013 2:59 pm
    To be honest, I don't think a Xeon offers any more performance for the money over the higher end consumer chips. And I think all you're really getting out of it is some extra "nice-to-have" features for servers and registered RAM support.
    Also the BGA versions are more likely to be nerfed for TDP reasons.
    PostPosted: Thu Jul 11, 2013 6:48 pm
    why would TDP matter if you are running a low/micro itx/matx system not needed for gaming.
    PostPosted: Thu Jul 11, 2013 7:56 pm
    Because the NUC has a much smaller space that limits how big of a cooling solution you can put in the chassis. The lower your cooling potential, the lower your performance is going to be... because TDP is a function of transistors, voltage, and frequency.
    To put in perspective, the current NUCs use processors that have a TDP of 17W. The latest Core i7s have a TDP of 84W.
