It is currently Mon Apr 27, 2015 1:53 am
 Post subject: New build advice on 1150 mobo & heat sink(H80i vs Evo)
PostPosted: Fri Jun 28, 2013 8:56 am
Team Member Top 250
Team Member Top 250
Gathering the components for a new build to replace my Q9300 system.
CPU: 4770k
GPU: GTX 760 Gigabyte windforce (probably add a second one later down the road)
RAM: 8 Gigs of G skill Sniper 2133
PSU: Evga Supernova 650W 80+ Gold
SSD: Corsair Neutron 256GB (maybe Mushkin 480GB)
HDD: Seagate 2TB 7200 Barracuda
Case: Undecided, mid ATX
Any suggestions on a motherboard? Looking to spend about $200 give or take. All the specs are so similar it's hard to differentiate.
Also, I'm debating between the Corsair H80i and Cool Master 212 Evo. I know these are very different price & performance points but here's my debate. The 4770k runs hot, so I lean towards the H80i especially since I am going to utilize that K on the end some. But, most of these don't overclock well, so more than likely I'll be able to push it just fine with the Evo using push/pull and take that $50 and apply it somewhere else.
Much appreciated,
Q1
 Post subject: Re: New build advice on 1150 mobo & heat sink(H80i vs Evo)
PostPosted: Fri Jun 28, 2013 11:00 am
CPU: 4770k
Much appreciated,
Q1
The 212 EVO will be good. As for sa motherboard, if it fits your budget an ASUS Z87 - Pro is good. I am using air cooling and have my 4770k OC'd to 4.6 Ghz and temps are not a problem and I only have a one fan option on the CPU with the Gelid Tranquillo. I can turn the Heat sink and fan so it will push ot the other way to pull.
PostPosted: Sun Jun 30, 2013 6:47 am
one of my friends mentioned lately the new biostar products for socket 1150 like the Hi Fi Z87X. So far its not yet available but maybe worth to wait for?
