It is currently Wed Mar 04, 2015 3:39 am
 Post subject: Need help building around my Gigabyte 7950 AMD Radeon
PostPosted: Fri Jun 28, 2013 11:59 am
Hi i need you're help finding a MOB,CPU,CASE i was looking to get a Intel-i5 can you guy's recommend one with a Motherboard that will work great with the CPU and GPU also i need a case that will fit everything with ease and and some room left for upgrade thanks.
 Post subject: Re: Need help building around my Gigabyte 7950 AMD Radeon
PostPosted: Fri Jun 28, 2013 2:55 pm
I think before we can get the motherboard, we need to know what kind of case you want. Something big? Small? Flashy? Minimalistic? And do you have a power supply, memory, and other stuff to complete the build? And a budget would be nice.
PostPosted: Fri Jun 28, 2013 4:33 pm
yeah sorry for late reply, yes i would need the case to be big because my Gigabyte 7950 AMD radeon GPU is currently too big for my case atm also i have everything i have 8 gig's of ram 1TB HDD a corsair 750W 80PLUS bronze PSU everything, also i'am gonna go with the Intel-i5 4670K too so i would need the motherboard to support that CPU and also i heard a guy saying getting a gigabyte motherboard would go great with a gigabyte GPU is that true? now the case would have to be spacious for room to upgrade in the future too, Budget well i was thinking about 400 euro's for Motherboard,Case,and CPU
400 euro's = $520 or £340
Thanks.
PostPosted: Fri Jun 28, 2013 4:44 pm
http://uk.pcpartpicker.com/p/1bl3y
I think the Phantom 410 fits. I would look around. But the the motherboard and CPU is about as cheap as I could get it.
PostPosted: Fri Jun 28, 2013 4:58 pm
Thanks man you're a legend.
PostPosted: Fri Jun 28, 2013 8:11 pm
you didn't say what kind of ram you have, it needs to be ddr3 to work with a new motherboard etc.
PostPosted: Fri Jun 28, 2013 8:23 pm
i have 8GB DDR3 1333Mhz Standard
PostPosted: Fri Jun 28, 2013 8:31 pm
sorry i just noticed that the motherboard you provided is micro ATX and the case is just ATX sorry it might be a newb question, if the budget is a problem i might be able to squeeze it to 450 euros for a better MOBO and CASE with the Intel core i5-4670k
PostPosted: Fri Jun 28, 2013 8:42 pm
It'll fit if that's what you're wondering. But when I was doing an initial run, I went up to like 550 euros, but I think the motherboard and processor itself took up 380 or something (the motherboard was a Gigabyte Z87 something something UD3H)
