It is currently Sun Apr 26, 2015 10:38 pm
 Post subject: upgrade help on a asus cm1745-04
PostPosted: Fri Jun 28, 2013 5:52 am
was wonderin what I should do first I play Wow and Swtor . I was thinking power supply graphics let me.know what you think and what would fit looking to buy from newegg
 Post subject: Re: upgrade help on a asus cm1745-04
PostPosted: Fri Jun 28, 2013 12:35 pm
Moderator
Moderator
It would help to know what you are currently using in order to help you with upgrade options. Also it's good to know what price range you are looking at.
PostPosted: Fri Jun 28, 2013 2:49 pm
I think a Radeon HD 7850 should get you going. I wouldn't worry about the power supply too much, but I'd be more comfortable with a 450W-500W one in the rig with a video card.
Unfortunately I can't really recommend much else beyond that, the CPU is kind of limiting and the motherboard won't let you upgrade to anything except other APUs.
