It is currently Sun May 03, 2015 3:18 pm
 Post subject: Computer Workstation question
PostPosted: Wed Jun 19, 2013 9:49 pm
OK, sorry this isn't a PC building question, but I don't really know where else to put it...
Anyway, I'm looking to purchase a work table for working on computers. I'd like to get something like those that has an adjustable shelf that's held in by screws or bolts. You know, the type that is used in PC repair facilities or server rooms. I"m only looking for 1 or two of them, so all of the resources I found thus far are for companies looking to buy in bulk or for schools, etc.
Does anyone know where I can get one of these workstation work tables? Basically I need a bottom shelf that can hold computers, a top work table area, and then an adjustable shelf or a mount that I can mount a monitor two to it.
Here is a link to something like what I"m looking for (this should give people an idea--doesn't have to be exactly like this):
http://www.google.com/imgres?imgurl=htt ... 9#imgdii=_
Here is another example:
http://www.google.com/imgres?imgurl=htt ... fZRc7fM%3A
Normally, I'd build something myself, but I rent for now so I can't really go mounting a bunch of stuff to walls.
 Post subject: Re: Computer Workstation question
PostPosted: Thu Jun 20, 2013 12:13 pm
newegg http://www.newegg.com/Product/Product.aspx?Item=9SIA1JH0GZ6286
