It is currently Mon Jan 26, 2015 12:39 pm
 Post subject: power supply tips
PostPosted: Mon Jun 10, 2013 9:37 pm
im thinking about changing power supply from 300 watts to a 500 watts, just asking is there anything i need to know when changing my power supply?
 Post subject: Re: power supply tips
PostPosted: Tue Jun 11, 2013 7:38 am
There's only three tips I can give. Find something that's 80PLUS certified. Consider a modular power supply (but if there's plenty of room in the case, I wouldn't worry about it). Get something from Seasonic, Corsair, or Antec.
PostPosted: Tue Jun 11, 2013 5:52 pm
If you want more research, there are sites that do full reveiws of psu. Tear downs and testing. I can think of:
http://www.jonnyguru.com/
www.hardwaresecrets.com
PostPosted: Tue Jun 11, 2013 9:30 pm
just wondering, does it matter what brand my pc is because its a hp so will replacing the power supply work?
PostPosted: Tue Jun 11, 2013 9:48 pm
It should, I haven't heard HP using non-standard parts.
PostPosted: Wed Jun 12, 2013 4:59 am
You might want to double check dimensions inside the case too to make sure it all fits.
PostPosted: Wed Jun 12, 2013 7:32 am
would upgrading my power supply help my graphics card because it seems to be really laggy even on low settings?
PostPosted: Wed Jun 12, 2013 7:42 am
No. You'd have other problems if you power supply wasn't enough.
PostPosted: Wed Jun 12, 2013 3:05 pm
one last question, does it matter what type of pci express when it comes to graphics card or are they all the same and will work?
PostPosted: Wed Jun 12, 2013 6:40 pm
No, not really. To put in perspective, a GTX 680 doesn't start getting hurting in performance noticeably until you plug it into something slower than PCI-Express 1.1 x8 / PCI-Express 2.0 x4 / PCI-Express 3.0 x2
