It is currently Sun Mar 01, 2015 7:37 pm
 Post subject: Crysis Ultra
PostPosted: Fri May 31, 2013 8:35 pm
Hi! I have heard of an Ultra Setting on Crysis and Crysis Warhead, how do I access it? The highest setting I have seen is Enthusiast, but I have heard of an Ultra setting and here it shows benchmarks that say they are using the Ultra setting on 1920x1080.
http://www.anandtech.com/show/6774/nvid ... nveiled/10
Also is "Very High" the highest possible setting in Crysis 3? Is there an Ultra? I'd appreciate some help! :)
Thanks! :)
 Post subject: Re: Crysis Ultra
PostPosted: Fri May 31, 2013 11:08 pm
Ultra is synonymous with "Very High" and "Enthusiast". There is no such mode.
PostPosted: Fri May 31, 2013 11:09 pm
PostPosted: Wed Jun 05, 2013 1:54 pm
Hmmm... OK. I thought there was, I thought I heard that it was added as a setting that could be used on Future Hardware. Also I saw someone use 16XAA with it (from the game settings, NOT using the Nvidia control panel) and I only have 2,4 and 8X AA. But if it doesn't exist, it doesn't exist. Thanks! :)
Also, I installed my extra two GTX 580's last night, running Tri SLI, and they run like a dream! :D All my games feel faster, even the ones I played at a locked 60FPS before. But Batman Arkham City runs smooth but gets a bunch of slow downs, like the frame rate feels like it's dropped from 60FPS to 15FPS. But it only happens when I am moving around the city. If I stay in one spot and move the camera around it goes perfectly fine, it is also fine if I just stay in one general area and move around. But if I start moving around the city it gets random major FPS drops like every 10 -15 seconds, it ran before on one 580 just fine with max settings and 4X AA with 30-45FPS, now I'm using max with 32X AA and a locked 60FPS(except for the slow downs). If you have a suggestion on how to fix it I'd appriciate the help! Thanks! :)
PostPosted: Thu Jun 06, 2013 11:19 pm
OK, I was playing Crysis 2 and then it froze, a second later the screen went black and the PC wouldn't respond, I had to hold down the power button to shut it off. Any idea why it would do this? Thanks! :)
PostPosted: Thu Jun 06, 2013 11:31 pm
Ran Crysis 2 again and... same thing. Not sure if its the spot in the game or what, its where you first enter NY City, I needed to open the security doors and it froze right when I walked up to then and had just started trying to open the door, the first time though it froze after I opened them, I was glancing at a mutated body to the right just after going through. Gonna run Unigine Valley for a while, see what happens. Thanks!
PostPosted: Fri Jun 07, 2013 12:13 am
Unigine Valley and Crysis 3 are fine, Unigine showed this...
GPU 1: 91C
GPU 2: 85C
GPU 3: 89C
