It is currently Tue Mar 31, 2015 12:33 am
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2
 Post subject: Re: New build - won't boot.
PostPosted: Sun May 26, 2013 6:41 pm
Replace the motherboard then, and just because you may as well on Nasty's suggestion, the CPU too.
PostPosted: Sun May 26, 2013 8:35 pm
RMA the motherboard. It is defective and is most likely DOA.
PostPosted: Sun May 26, 2013 8:56 pm
And if it's still not booting, then memory.
And if it's still not booting... power supply :D
PostPosted: Mon May 27, 2013 2:53 am
When you cleared the cmos by removing the battery, did you unplug the computer from the wall? If not, you didn't reset the cmos. You should have unplugged the computer from the wall, pushed the start button for about 20 seconds, then pop the battery or use the shorting jumper to reset the cmos. Your computer never really turns all the way off, it is like your TV instant on because there is a small amount of juice still running in your board.
PostPosted: Mon May 27, 2013 3:18 am
I didn't unplug it from the wall. I'll try that.
PostPosted: Mon May 27, 2013 5:52 am
Stephen wrote:
No luck.
PostPosted: Mon May 27, 2013 11:07 am
Time to RMA parts I guess, as in motherboard and cpu.
PostPosted: Mon May 27, 2013 12:02 pm
Yup!
PostPosted: Wed May 29, 2013 4:19 pm
I RMA'd it today!
PostPosted: Thu May 30, 2013 3:21 am
Keep us informed when things get put back together! :D
PostPosted: Sat Jun 15, 2013 2:47 am
I received the repaired motherboard back, built the compute with no problems. One thing that seems a bit odd – the motherboard temps are about 6 degrees higher at idle than the pro version of the board. Same case, same case fans, different CPU and different CPU cooler, different graphics card, same memory. The CPU temps are essentially the same. The pro board mobo temps at idle are running 30c, while this mobo temps are running at idle at 36c. Is this typical?
PostPosted: Sat Jun 15, 2013 5:07 am
Not all electronic parts are created equal. They have build tolerances like anything else, so your new board may have more resistance in the end than your premium board. I think it is called reluctance, the sum total resistance of all electronic parts in a circuit. I have been out of school for fifty years, so I could be wrong....God! Getting old sucks!
I wouldn't worry about the temp differential.
PostPosted: Sun Jun 16, 2013 11:49 am
Thanks.
PostPosted: Mon Jun 17, 2013 8:28 am
Stephen wrote:
joyand wrote:
Might be the standoffs shorting the mobo. I would test if it posts outside of the case.
Tried that. Didn't post outside the case.
On your CPU connection from the PSU, are you using a 4 Pin or 8 pin connection ? With that processor, it should be 8 Pin. Not sure of what the requirements are on the Processor and what is provided by the PSU either.
PostPosted: Wed Jun 19, 2013 9:26 am
Good to hear its working! sorry i was late to the party. rule of thumb with most builds, no post sounds at all indicate short, damaged mobo, or damaged(or big enough) psu... at least 99% of the time.
PostPosted: Fri Jun 28, 2013 11:21 am
With that Mobo, if the LED at the CPU is lit, than that is where the fault is. If it had been lit at the Memory, then that would have been the issue. Recheck you CPU and make sure there are no bent pins in the socket Also, make sure that the 8 Pin CPU connector is frmly plugged in as well as the 24 pin ATX connector and above all else the CPU is in the socket correctly ( I have seen it otherwise ).
PostPosted: Fri Jun 28, 2013 3:27 pm
Did all that, RMA's board, got it back repaired, and am now up and running fine......
