It is currently Sat Apr 25, 2015 1:16 am
 Post subject: Hey MS, do I really need 19 Microsoft Visual C++ files?
PostPosted: Thu May 23, 2013 3:10 pm
Million Club - 20 Plus
Was putzin' around in the computer today and while looking for errata to delete, I noticed this.
19 Microsoft Visual C++ files listed. I have to assume that most are updates of older files. If that is so, why aren't the older files removed when updated? I can't assume that they would be okay to remove myself as they weren't removed automatically.
MS, do I REALLY need 19 Microsoft Visual C++ files?
2005 ATL Update kb973924 - x64 version 8.0.50727.4053
2005 Redistributable version 8.0.61001
2005 Redistributable version 8.0.56336
2005 Redistributable version 8.0.59193
2005 Redistributable version (x64) 8.0.61000
2005 Redistributable -KB2467175 version 80.51011
2008 ATL Update kb973924 version 9.0.30729.4148
2008 Redistributable KB2467174 -x64 version 9.0.30729.5570
2008 Redistributable KB2467174 -x86 version 9.0.30729.5570
2008 Redistributable X64 version 9.0.21022
2008 Redistributable X64 version 9.0.30729
2008 Redistributable X64 version 9.0.30729.17
2008 Redistributable X64 version 9.0.30729.6161
2008 Redistributable X86 version 9.0.21022
2008 Redistributable X86 version 9.0.30729.17
2008 Redistributable X86 version 9.0.30729.4148
2008 Redistributable X86 version 9.0.30729.6161
2010 X64 Redistributable 10.0.40219
2010 X86 Redistributable 10.0.40219
OS is Windows 8 64bit, Classic Shell
 Post subject: Re: Hey MS, do I really need 19 Microsoft Visual C++ files?
PostPosted: Thu May 23, 2013 3:55 pm
Because this is how backwards compatibility works in real life. Even if you made you libraries backwards compatible, whatever you did could cause unwanted side effects in the program that used a previous version of the library. So if you want to guarantee your software works, ship it with only the libraries its compatible for and install it.
