It is currently Sun Mar 01, 2015 1:08 pm
 Post subject: It's dead... mostly, I think
PostPosted: Tue May 21, 2013 5:34 am
Hello,
I am looking at a computer with a A8N-SLI-Deluxe motherboard. It POSTs but will not boot. Says there is no boot dive. There are 4 SATA drives in the computer, one 150G Velociraptor with the OS, two 250G WD drives and one optical drive. There is also a floppy A drive (yikes!).The BIOS shows no drives except the A drive. I transplanted a known good drive in (with all others drives disconnected) and get the same result. I put the Velociraptor in another computer and it boots no problem. I tried pulling the BOIS battery and that had no effect, expect to reset all the setting to default.
Additional info. In the RAID configuration it says there are two few drives to create a RAID, that is with all the drives plugged in.
Is it dead?
Thanks
 Post subject: Re: It's dead... mostly, I think
PostPosted: Wed May 22, 2013 8:33 am
I would not say it is completely dead--just the onboard SATA controller and its SATA ports. You could always try using an add-on SATA controller card to bypass the issue, if you are so inclined.
PostPosted: Thu May 23, 2013 2:52 am
Hmm, that is an idea I had not considered. Thanks, I'll give that a try.
PostPosted: Thu May 23, 2013 3:38 am
Don't order anything until you look at the electrolytic caps! If any are split, leaking or bent way over like in the pictures below, the board is dead.
http://www.google.com/search?q=bad+caps ... 20&bih=950
PostPosted: Thu May 23, 2013 6:30 am
Thanks for the advice on the caps, they are all clean.
PostPosted: Thu May 23, 2013 11:41 am
Did you try changing the sata cable and use a different power plug from the psu?
PostPosted: Fri May 24, 2013 2:54 am
yes, I was able to swap drives with a known good computer. The drive spins up and I did use a different cable and I tried all the SATA ports on the board.
PostPosted: Fri May 24, 2013 12:51 pm
If the drive is read and you see data on it in another computer I would have to agree with Pcstudent and say the controller is dead.
