It is currently Tue Apr 28, 2015 5:11 am
 Post subject: Nvidia card for ASUS VG248QE 24
PostPosted: Wed May 15, 2013 6:53 pm
I miss my NEC CRT so I am going to be getting the Asus VG248QE 24" 144Hz Monitor for my next build and I want to go with Nvidia so I can try the lightboost 2d thing and the monitor overclocking. What would be a good card to go with for this monitor? I'm guessing a Titan would be overkill for the max resolution of the monitor at 1920x1080. What other Nvidia cards support monitor overclocking and 2d lightboost?
 Post subject: Re: Nvidia card for ASUS VG248QE 24
PostPosted: Wed May 15, 2013 8:10 pm
Video cards don't do "monitor overclocking", and in fact, monitor overclocking involves going into the electronics and tinkering with it.
Also 2D is pretty much "lolwut?" work for a GPU these days. Hell an Intel HD2000 would have no trouble doing 1080p@144Hz
PostPosted: Wed May 15, 2013 8:42 pm
http://www.rockpapershotgun.com/2013/03/04/week-in-tech-overclock-your-monitor-with-nvidia/
http://www.blurbusters.com/nvidia-3d-lightboost-can-be-used-in-2d-mode-for-zero-motion-blur/
PostPosted: Wed May 15, 2013 9:22 pm
Aha... I think it's a gross misnaming to call "sending more frames than you're actually rated for" monitor overclocking. But whatever. And if it's EVGA that's the only tool that will let you force a higher refresh rate, then chances are, you're limited to EVGA cards.
In any case, it looks like this is a 3D thing, so pretty much anything that supports NVIDIA 3D should support LightBoost, if the monitor supports it. And either way, you're getting a 144Hz monitor, I think you should play with that before being dissatisfied with it, because at that rate, you're way beyond the threshold for human reaction time.
