It is currently Fri Jan 30, 2015 2:12 am
 Post subject: No video on first boot
PostPosted: Fri Apr 26, 2013 5:52 pm
Hey guys, I have a strange problem. I have an ASUS M3A79-T Deluxe that I have been running a pair of GTX-460's in for about 2 years with no problems. The other day I pulled one of them out, leaving only one in the system. Since then about half the time when I start the rig up I have no video. I then hard reset it and the video comes back to life on the next boot. I have completely disassembled it in a rebuild today, replacing the heatsink and installing an SSD, and when I started it up to install Win 7 Pro it did the same thing.
When I had it apart I blew out all the slots, video card, and everything else. Any ideas what might be causing this?
Thanks in advance...:)
 Post subject: Re: No video on first boot
PostPosted: Fri May 03, 2013 3:30 am
Did you shut off SLI in the video driver before pulling the second card out? There may be an option in the bios to boot to a single video card as well, change it to one card if it is there.
PostPosted: Fri May 03, 2013 8:16 am
The video driver is smart enough to figure this out.
There is no BIOS option, and there never was. The closest thing was a little card that you'd have to flip if you were using SLI. But even then, this only configured the PCI-Express lanes, and this was all fixed by PCI-Express 2.0 (which this board has).
Still, it wouldn't hurt to reset BIOS to factory default settings. And I've taken it you've tried both cards and both DVI ports?
PostPosted: Fri May 03, 2013 3:38 pm
I don't see how he ran SLI when the board only runs Crossfire....
http://www.asus.com/Motherboards/M3A79T ... ifications
PostPosted: Fri May 03, 2013 6:56 pm
Actually I never had the SLI bridge on the cards. But I swapped the cards between the two rigs and each one works fine now. I have no idea why one cards didn't like this MB but has no problem with a P6T Deluxe, but I'm past the point of trying to figure it out...I'm just glad it works.
Users browsing this forum: keithculbreth and 8 guests
