It is currently Sun Mar 01, 2015 11:55 pm
 Post subject: Game Resolution Issue
PostPosted: Mon Apr 29, 2013 7:17 am
So I have a slight problem with a game: Star Wars Republic Commando.
For some reason the resolution will not change from 640x480, which is horrible.
I cannot get the 1600 x 1200 resolution to lock in, it always reverts to the 640 resolution. Any suggestions? Anyone have any experience with this kind of issue with older games?
Thanks B)
 Post subject: Re: Game Resolution Issue
PostPosted: Mon Apr 29, 2013 7:17 pm
I think we need a little more info.
What are the computer's specs?
What kind of video card?
Is the 1600x1200 the monitor's resolution? And can you get this resolution with all the other programs?
Are there other games causing problems?
Are your drivers updated?
Have you changed the settings in the game? It's usually under Options
I hoping this may spark something for you to check.
Hope this helps.
PostPosted: Mon Apr 29, 2013 8:42 pm
If the screen goes black and stays that way for 10-15 seconds before going back to 640x480, it probably means your monitor doesn't support that resolution. Try others if you can.
PostPosted: Tue Apr 30, 2013 5:39 am
I have the following:
A Latitude E6420
Intel Core i5-2520
Nvidia NVS 4200M
4 Gigs of Ram.
All of the components are onboard.
I do not know If I have updated the video drivers, it is a government computer so that may be complicated to do.
The screen does not go black when changing the resolution.
I do know that this is a common problem with Republic Commando as certain resolutions were not widely available when the game came out.
I have tried changing the resolution multiple times to no avail, I also tried the following sites solutions:
http://www.blubrry.com/datacast/465791/how-to-set-a-custom-wide-screen-resolution-in-star-wars-republic-commando/
http://forums.steampowered.com/forums/archive/index.php/t-1506206.html
Both of the sites suggest changing some info on the system.ini file in the game folder, but that still did nothing. Perhaps I was doing it wrong?
Thanks guys
PostPosted: Thu May 02, 2013 7:37 am
So quick update:
I'm currently downloading the latest video driver from dell. I looked around and it seems that a lot of people have had this issue with Republic Commando (RC) in the past due to its lack of widescreen support.
I will let ya'll know if the driver fixes anything.
Thanks
