It is currently Sat Apr 18, 2015 1:23 am
 Post subject: Question about upcoming Z87 Motherboards
PostPosted: Sat Apr 27, 2013 6:08 pm
I was reading the Maximum PC article about the upcoming MSI Z87 Motherboard and it stated "Like the XPower motherboard, it would be powered by two 8-Pin EPS connectors". What are EPS connectors? Will I need a new power supply to power the Z87 Motherboards? I have an OCZ 750 watter that I bought a little while back and I'd like to use it on my next build.
 Post subject: Re: Question about upcoming Z87 Motherboards
PostPosted: Sat Apr 27, 2013 7:52 pm
You know those plugs you put in next to the CPU? That's an EPS plug (as long as it's the 8-pin version... which most motherboards use)
Though I see it says it requires two. Those bastards. That will require a new PSU. You only get 1 4+4 EPS plug
PostPosted: Sun Apr 28, 2013 6:33 am
Oh geez, that sucks. I had configured my rig to around $1000, now I gotta trim some fat or save up some more money to add a PSU to it, lol. Do you think ALL Z87 Motherboards will require 2 EPS plugs or just the MSI one?
PostPosted: Sun Apr 28, 2013 8:50 am
I'm pretty sure all the motherboard manufacturing companies are showing off their flagship $200+ products. And chances are it's only MSI's. I'd wait until the products actually come out before making any decisions.
PostPosted: Sun Apr 28, 2013 9:24 am
knowing that no power supply has two 8 pin connectors, it seems like they would include an adapter for the second one.
PostPosted: Sun Apr 28, 2013 10:27 am
Ah, should've looked this up. Apparently there's a few power supplies that do have 2x 8-pin EPS connectors (http://www.hardwarecanucks.com/forum/po ... n-eps.html), Corsair AX750 being one of them.
Although in reality, most computers don't need the whole 8 pins.
