It is currently Sun Apr 19, 2015 3:04 pm
 Post subject: How Can I Know if Mobo Battery Bad??
PostPosted: Sat Apr 13, 2013 12:52 pm
My system is OC'd but I don't think that is why every 3rd or 4th start up has BIOS settings reset. I don't have any heat issues and everything is fine when I use pc OC'd. I have the AMD FX-8350 OC'd at 4.4ghz, 1.41 volts which is more than enough electricity.
Thought maybe the mobo's battery is going out. Any idea how I can test this?
 Post subject: Re: How Can I Know if Mobo Battery Bad??
PostPosted: Sat Apr 13, 2013 2:26 pm
A voltmeter.
PostPosted: Sun Apr 14, 2013 8:12 am
To be honest, in all the years I have been building systems, I have only had 1 go out, and that system was like 8 years old. They are the same battery that most watches or keyfobs run on. They are supposed to last 5 years or so.
Easiest way to check, is to use a DVOM like Latios said, or make sure all the settings and date are current in the BIOS, and shut down the system, then remove the power cord from the PSU. Let it sit like 15 minutes and power it back up. If the settings and date stay the same, the battery is good, if not then the battery is bad.
