It is currently Thu Mar 05, 2015 8:09 am
 Post subject: i7 Processor w/ Integrated Memory Controller vs North Bridge
PostPosted: Fri Mar 29, 2013 6:23 am
Hopefully you can answer this Question I have for newer CPU hardware and North Bridge Chipset conflicts:
Now, Normally, the North Bridge chipset handles all the interaction between the CPU, RAM, Video, and South Bridge. If I wanted to purchase a Motherboard that can handle RAM speeds of "DDR3 2800+(OC)/2400(OC)/2133(OC)/1866(OC)/1600/1333/1066", and I also buy RAM that is DDR3-2800, I should have no issues with compatibility on this specific issue.
However, the new i7 Intel processors have an "Integrated Memory Controller: Dual-channel DDR3 Memory Controller supports DDR3-1333 and DDR3-1600 memory"
So, as I see it, if the i7 processor's integrated memory controller may limit me to DDR3-1600 memory, would the extra spent on DDR3-2800 RAM and Motherboard be wasted? Which takes precedence?
 Post subject: Re: i7 Processor w/ Integrated Memory Controller vs North Br
PostPosted: Fri Mar 29, 2013 10:12 am
You can set the memory profile on most of these motherboards so you can take higher speed RAM. But you probably won't notice anyway if you dropped to DDR3-1600 unless you have some memory constrained program you're running.
PostPosted: Fri Apr 12, 2013 3:49 pm
yeah, and treat it just like it's from the northbridge and just moved. There's still nothing really stopping you from running DDR3-2800 at it's advertised speeds besides the BIOS/UEFI settings.
